WipNav-WipCom: ricerca formato autovelox
Re: WipNav-WipCom: ricerca formato autovelox
Tool to extract LWD databases (in German):
http://forum.pocketnavigation.de/forum1 ... und-tools/" onclick="window.open(this.href);return false;
ciao mira,
Bravo
potresti mandarmi qualche stringa comprensiva dei check che provo qualche algotritmo?
Bravo
308 1600 Hdi grigio hurricane fendinebbia WipNav
li trovi in tutti i file LWD.lino1951 ha scritto:potresti mandarmi qualche stringa comprensiva dei check che provo qualche algotritmo?
in allegato ti ho messo 2 blocchi presi da un file lwd PSA.
in ogni blocco all'offset 16 ci sono 4 byte che contengono la lunghezza dei byte seguenti, escluso il checksum finale.
io non so dirti dove inizia la "stringa" per il calcolo del checksum/crc, forse all'offset 20, bho!
io ho provato varie combinazioni ma senza successo.
maybe i don't understand how to use these tools, but they seems not useful for extract radar informations from LWD.fonix ha scritto:Tool to extract LWD databases (in German):
have you try them ?
Yes, I have. The tools follow a general approach: the .db and .lwd files are in fact archives (just like zip) an can store all sorts of files. The tools posted by T|K can be used to extract or create such archives.
Usage:
navlwdb_tool.exe -vx hazwardareas.lwd
-> will extract the archive hazardareas.lwd to folder "hazardareas.lwd_contents"
-> the folder will contain several .raw files which contain the actual data
Usage:
In other words: navlwdb_tool and navfldb_tool work just like 7-Zip or other archivers. They allow you to extract and create FLDB and LWDB archives.
I think if we combine our efforts we might achieve the goal of getting a working POI editor.
Sorry for writing in English by the way, I'm German and sadly not able to speak or write in Italian.
ok. it is the same result i had, but the ".raw" files are unusable as is.fonix ha scritto:Yes, I have. The tools follow a general approach: the .db and .lwd files are in fact archives (just like zip) an can store all sorts of files. The tools posted by T|K can be used to extract or create such archives.
Usage:
the compress switch (-c) work in the same way, it pack togheter the ".raw" files, but we still don't know how to build them
Eccomi nuovamente all'attacco
, si fa per dire ne'....
chi mi prova questo file LWD (che sta dentro il .zip) su un WipNav ?
come per il test precedente, va messo sulla memory card al posto dell'attuale file hazardareas.lwd
mira grazie per il tuo impegno x migliorare sta ciofega di wipnap .............da un cugino che da tempo aveva rinunciato
robibebo
@ kishar
Sei riuscito?
facci sapere
Sei riuscito?
facci sapere
Peugeot 508 RXH 2014
robibebo
Ora ho trovato qs link a pagamento , ma non risolve il mio problema.
La mi sd card quando la metto nel lettore del mio pc , non viene letta e non capisco il perchè!!!!!
robibebo
Oooppsss
ecco il link http://www.speedcamupdates.it/Peugeot-WIP-Nav" onclick="window.open(this.href);return false;
robibebo
Allora:
risolto problema alla sd card ,ora il pc la legge....
Installato e regolarmente in uso file hazarareas
Vi chiedo se gli aggiornamenti sono frequenti e come faccio a sapere quando c'è a giro un file aggiornato da poter acquistare.
Paperoga71
Scusate sono nuovo del ottimo Forum
Ho provato a installare gli autovelox, ma l'opzione del menù del 3 wip rimane inibita e quindi non mi fa procedere all'istallazione.
Come posso fare?
Grazie a tutti e complimenti
Lorenzo
Come posso fare?
Lorenzo
Bonjour,
une information si elle peut être utile:
sur un autre site:
http://gpsmyway.superforum.fr/t12p90-te ... i-mai-2012" onclick="window.open(this.href);return false;
un internaute dit avoir trouvé une information sur un site allemend
utile ????
bonne journée
sur un autre site:
utile ????
bonne journée
