spia livello olio: NON CI CREDO!!!
Deimos
Messaggio da Deimos »
guardate che ho trovato!!!!
Document created: 03. 04. 2003
Last updated: 27. 12. 2003
DAM 9506
206 XT Manual
1.6 litre
5 door
NFU BOSCH ME744
Note: Specialized equipment is required to carry out this operation.
BSI Configurations
ECUs present
Trip computer/display/data communication ECU/PC, auto micro:
present
High frequency Japan:
absent
Driving school instructor's control unit
absent
Radio:
present
Automatic lights:
present
Alarm unit:
absent
Air condition ECU:
absent
Fuel additive control unit:
absent
Parking aid ECU:
absent
Compact disc player:
absent
Sunroof control unit:
absent
Steering wheel angle sensor:
absent
Automatic transmission control unit/controlled manual gearbox ECU:
absent
Air bags and pretensioners unit:
present
Switch unit under steering wheel[com 2000]
present
Built in systems interface[BSI] multiplexed ECUs:
present
Instrument panel:
present
Engine management control unit:
present
Anti-lock brake control unit/stability checking ECU:
absent
### under the bonnet :
Brakes :
Without ABS/ESP
Air pump :
absent
Oil temperature sensor :
absent
Coolant level sensor :
absent
Water in diesel sensor :
absent
Water in diesel information :
BSM
Automatic gearbox :
absent
Fluid level: -Info*-
*:It is important to configure this new parameter after a BSI update
for the oil level gauge to work correctly
Deimos - 206CC '03 1.6 16v ICE
" ° O o _ -- 2 O 6 -- _ o O ° "
Alpine CDA9835R + Technology LS29neo + Zacks CWF165.9 + 2x JL 6w0-8 (F3: 38Hz!!) + Protos VR 4.400 + Steg QM 45.2
cozval
Messaggio da cozval »
Cioè? :?:
Le mie peugeot :
2004 307 1.4 Hdi 70 CV XT con pack elettrico - Grigio alluminio
2006 307 1.6 Hdi 110 CV XS con pack elettrico, pack visibilità, ESP - Nero obsidiana
2008 308 1.6 Hdi 90 CV FAP TECNO con clima bizona e caricatore CD - Nero Perla
2015 2008 1.6 Hdi 100 CV ALLURE - Grigio platinum - navigatore - cerchi da 17"
2016 Nuova 208 (macchina della moglie ) - 1.2 puretech 82 cv - bianco banchisa - retro camera e navigatore
Prowler
Messaggio da Prowler »
SE ho ben capito sono tutti i parametri che vedi con il DIAG ... l'ultimo deve essere impostato quando resetti la BSI altrimenti l'indicatore dell'olio fa' un po' quello che gli pare.
Ho capito giusto ?
Passione Peugeot Card n.1
Deimos
Prowler ha scritto:SE ho ben capito sono tutti i parametri che vedi con il DIAG ... l'ultimo deve essere impostato quando resetti la BSI altrimenti l'indicatore dell'olio fa' un po' quello che gli pare.
Ho capito giusto ?
si, il succo è qudello (ho postato solo la parte INTERESSANTE della config della bsi, non tutta)
Chalys
Messaggio da Chalys »
Onestamente non ho capito di cosa si sta parlando :shock: :?: :?:
Peugeot 307 XT 5p 2000 HDI 110 CV - Grigio sidobre - Maggio 2004
Pack elettrico 3 - Pack visibilità - Allarme perimetrale e volumetrico - Cruise Control After Market
Prowler
Un alto numero di possessori di 307 lamenta il fatto che l'indicatore dell'olio fa' le bizze ... indica una volta pieno e una volta vuoto, risultando del tutto inaffidabile.
Quello che ha segnalato Deimos puo' essere il motivo, cioe' che se viene per qualche motivo aggiornata la centralina BSI (la principale) e' necessario configurare il parametro "fluid level" per far funzionare correttamente l'indicatore.
Torna a “Generale”
